G+_Eddie Foy Posted March 2, 2015 Share Posted March 2, 2015 So whats the difference between a cable qualifier vs certifier? (besides the $9000 price difference; $1k vs $10k) Pondering the Fluke CIQ-100. It says it qualifies 10/100/Gb/VoIP Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted March 2, 2015 Share Posted March 2, 2015 http://lmgtfy.com/?q=cable+certifier+vs+qualifier Hehe. The first link is probably an ad for an Ideal product, but explains the difference. A Certifier will measure the electrical properties of a cable and tell you whether they fall into spec for that cable type. A qualifier seems to pass normal network traffic across the cable and measures data rates. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted March 2, 2015 Share Posted March 2, 2015 The company I used to work for had 1 certifier for the whole company and every tech (about 5 of us) had simple continuity testers they we used day to day. Occasionally though we would get a customer that required cable certification. It was a longer process especially since a cable could be fully functional and still fail certification. Link to comment Share on other sites More sharing options...
