G+_Eddie Foy Posted June 2, 2015 Share Posted June 2, 2015 RADIUS/WIFI issue. I have a Synology NAS running a RADIUS server Asus RT-N66R router (as an AP only) I can connect no problem via 5.8GHz, but 2.4 won't. PEAP with User/PW authentication. I've only tried it with Android devices. Anything with a RJ-45 gets wired. (just gave a shot on a MBP, same deal 5.8 is OK, 2.4 isn't) Also tried the guest network with no joy. Ideas? Link to comment Share on other sites More sharing options...
G+_Joshua Hamlett Posted June 3, 2015 Share Posted June 3, 2015 I'm not super familiar with RADIUS, but my guess is that that is not where your problem is. I take it nothing connects to the router on its 2.4 GHz channel at all? The problem is not with the RADIUS authentication? I would reset the wireless router, check its settings, and make sure that there isn't interference coming from other Wireless APs or other electronic devices. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted June 3, 2015 Author Share Posted June 3, 2015 Thanks. Was typing a replay when a light bulb went off (wrong one, but found the right one in my search.) Seems for some reason the 2.4GHz and 5.8GHz on the router can have different passwords to the RADIUS server (which is separate from the user name/pw authentication of the wireless clients) Working now. Didn't matter much, my current cell and tab support 5.8, just the old stuff doesn't. Link to comment Share on other sites More sharing options...
G+_Michael Heinz Posted June 4, 2015 Share Posted June 4, 2015 Remember to turn off your quadcopter's radio controller when you get home - it might be interfering.... ;-) Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted June 4, 2015 Author Share Posted June 4, 2015 It was the dual passwords for the router>radius server. Link to comment Share on other sites More sharing options...
