G+_Eddie Foy Posted July 12, 2015 Share Posted July 12, 2015 After another ABS print sticking too good (cracked another glass) I tried a sheet of Laser transparency film. I 'glued' it down to the glass with hairspray, and used my usual ABS/Acetone slurry on top. The hairspray wasn't the best choice. it kinda bubbled up at the nozzle on the first layer, but the print went well and removing was just an easy peel of the film. Going to play with different low tack adhesives for film to glass. Link to comment Share on other sites More sharing options...
G+_Morne Smith Posted July 12, 2015 Share Posted July 12, 2015 Try using Pritt? Or material SK100 Link to comment Share on other sites More sharing options...
G+_Jim Sauber Posted July 15, 2015 Share Posted July 15, 2015 There are glue sticks of the same glue used for 3M Sticky Notes. Works great for many temporary gluing jobs. Check how it reacts to heat first. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted July 16, 2015 Author Share Posted July 16, 2015 I had one some years back. Been tough to find locally. Gonna try out some 'washable' glue stick. Link to comment Share on other sites More sharing options...
