Help! Got a weird problem I have a vanilla cable internet connection coming into an old TPLink ...
G+_Rich Fowler
Help! Got a weird problem. I have a vanilla cable internet connection coming into an old TPLink router running DDWRT. I have tried adding a switch to the router (to get extra ethernet ports), and every time I fire up the switch, the Internet craps out. I can't figure out if it's the router freaking out or if it's my Evil ISP somehow messing with my switch. (Which sounds dumb as I type it, but I won't put anything past Time Warner.)
This is how I'm firing things up: first, cable modem, second, switch, third, router. I've also tried modem, router, switch, but that also doesn't work. In fact, just having the switch connected, even though it's *not* drawing power, is causing me to lose internet connectivity over the WAN connection. (Which is really making me think it's time to buy a new DDWRT-compatible router...)
If it's a dying router, do you have any recommendations for good DDWRT-flashable routers?
Ideas? Thoughts? Appreciated!
#switch #router #badmojo
The order should be modem -> router -> switch.  Can you power the switch on, then plug it into the router?  Your symptoms sound like more than 1 network cable is plugged into both the router and the switch.  Assuming that's not the case something is wrong with the router or switch.  Could you take the switch somewhere else to test?
To answer all the questions: I have tried the modem->router->switch order. That was the first one I tried, and it didn't work on two switches.
I have tried regular patch cables and crossover cables. 2-3 different cables. Same result.
I have checked all connections, and only one item was plugged into the switch-- my laptop I use for streaming TWiT. It has a 50-foot run, and that's it. (That and the patch cable to the router.) It runs fine off of the router.
And yeah, I've tried a TPLink switch and now a Netgear switch. Same problem. Both are unmanaged. The router is an older TPLink running DD-WRT.
And yes! I've even done a 30-30-30 reset on the router! I'm stumped!
