G+_Darryl Gibbs Posted May 29, 2015 Share Posted May 29, 2015 Hey all, I'm wanting to be able to monitor data usage by device/IP on my home network. Are there any free software options for this? Thanks! Link to comment Share on other sites More sharing options...
G+_Mikel Venable (techmv) Posted May 29, 2015 Share Posted May 29, 2015 I use pfsense firewall for this. I can also throttle the bandwidth based on ip or Mac. It will run on a wide array of devices from a link sys router to a i7. Link to comment Share on other sites More sharing options...
G+_Darryl Gibbs Posted May 29, 2015 Author Share Posted May 29, 2015 This will work with just a standard isp type router, or does it require a router with some kind of feature set? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted May 30, 2015 Share Posted May 30, 2015 PfSense is a software router for the computer. What type of monitoring are you looking for? Just bandwidth usage or IP address logging too? Link to comment Share on other sites More sharing options...
G+_Darryl Gibbs Posted May 30, 2015 Author Share Posted May 30, 2015 Simple monitoring. I just want to know which device on my network is sucking the most bandwidth. Thats it. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted June 1, 2015 Share Posted June 1, 2015 We covered this a while back... the episode number escapes me. Use an old laptop, a 100Mbps hub, and Wireshark. :) Link to comment Share on other sites More sharing options...
G+_Darryl Gibbs Posted June 1, 2015 Author Share Posted June 1, 2015 I'll take a look for that! Thanks Fr. Robert Ballecer, SJ Link to comment Share on other sites More sharing options...
