G+_Dan Hockey Posted March 21, 2017 Share Posted March 21, 2017 I have a DS716+II that's been running for about a year now, using 2 wd 2tb red drives. I've only used about 15% of space so far so I got another wd 2tb red drive. I'd like to put the new drive in and swap out one of the old drives and let the new drive run for a year. Do I just pull out one of the disks and put the new in? Would it speed things up if I format the new disk first? I don't remember what I did to the disks when I first set it up. It's currently using the btrfs file system. I haven't found anything in the storage manager that would let me unmount a perfectly good drive so I can remove it. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted March 21, 2017 Share Posted March 21, 2017 Don't format. Don't power down. Check to make sure you're running a mirror. If you are, then hot-swap one drive with your new drive. Log in and once it has finished mirroring, you're all good. Link to comment Share on other sites More sharing options...
G+_Derek Holmes Posted March 21, 2017 Share Posted March 21, 2017 If we do this, is it safe to consider the drive you pulled out a backup? Or is that data still at risk of being wiped when I insert it back into the NAS? Link to comment Share on other sites More sharing options...
G+_Jeff Gros Posted March 22, 2017 Share Posted March 22, 2017 I would perform a scrub of the volume before removing anything if you have a choice. This should remove any lingering bit rot. Btrfs should help the system decide which drive is correct if they disagree. Link to comment Share on other sites More sharing options...
G+_Dan Hockey Posted March 23, 2017 Author Share Posted March 23, 2017 I pulled one drive out and put the new drive in . Had to go into the storage manager and tell it to re-sync with the new drive. So far it's a rather painless procedure. It's now syncing. This brings up a new question, what will it do when I put the old drive back in? Will it ask to wipe the drive like it did when I installed the new one? Maybe I'll have to try it when it's done syncing. Link to comment Share on other sites More sharing options...
