G+_Mikkel Flindt Heisterbe Posted April 6, 2017 Share Posted April 6, 2017 I'm starting to build my electronics kit and keep coming across the need for capacitors. Now there are loads of capacitors on eBay and multiple kits but I cannot find what kit I should get. I'll need some 0.1 uF capacitors for my esp8266 programming but also see references to 101's multiple places. If any has recommendations for a kits of capacitors or a list of which capacitors i should get I would love to hear it. Also if they should be electrolytic or ceramic. Thanks! Link to comment Share on other sites More sharing options...
G+_Pat Hacker Posted April 6, 2017 Share Posted April 6, 2017 Me to Link to comment Share on other sites More sharing options...
G+_Josh Frye Posted April 7, 2017 Share Posted April 7, 2017 Have you tried Jameco? jameco.com - Jameco Electronics - Electronic Components Distributor Link to comment Share on other sites More sharing options...
G+_Mikkel Flindt Heisterbe Posted April 7, 2017 Author Share Posted April 7, 2017 Thank you. But it's not a matter of finding a place to buy but more what/which to buy... Link to comment Share on other sites More sharing options...
G+_Jason Marsh Posted April 7, 2017 Share Posted April 7, 2017 I seem to recall Fr. Robert Ballecer, SJ mentioning this once, and for some reason I think he was keeping a bunch of 1, 10, and 100 micro-Farad. Don't forget you'll want to keep electrolytic and ceramic (cans and discs) for your varied projects. Link to comment Share on other sites More sharing options...
