G+_Steve C Posted August 12, 2015 Share Posted August 12, 2015 Help with AR Drone 2.0 Elite Edition? Does anyone here have experience with this model? I picked up one today at Goodwill and it seems to be in good shape with all the parts in the box including a spare battery but when I connect the battery the LED goes red, then green and all 4 motors buzz a couple times then the LED goes red then it shuts off for a couple seconds and then repeats. It won't stay on and the Wi-Fi won't come on at all either. The manual has almost no information on how to start it up. Can the USB connection be used with a PC to run some diagnostics to see what's wrong or at least check the status? Link to comment Share on other sites More sharing options...
G+_Revolution 420 Posted August 12, 2015 Share Posted August 12, 2015 Sorry my friend, but you are a victim of a "USED PRODUCT" RC Controlled aircrafts requires "common sense" if you want to buy cheap... You will only get cheap... If you want quality, you must buy quality... Link to comment Share on other sites More sharing options...
G+_Steve C Posted August 12, 2015 Author Share Posted August 12, 2015 Review on Amazon are pretty bad with lots of early failures. I feel sorry for the suckers who bought these things new and paid $300 for a piece of junk that's not worth more than $50 or so at the most. Parrot products are such rubbish I don't know why they haven't been sued out of business yet but since I got it cheap it should be fun to play with for a while. The problem seems to be the motor lights stay red and never go green. I wonder what that means? Link to comment Share on other sites More sharing options...
