G+_Dan Salter Posted April 14, 2015 Share Posted April 14, 2015 My battery charger has started showing "Connection Error". I've tried straight charge and balance charging. I've tried different batteries and I've tested the cables. Everything seems ok. Any ideas? I'm guessing the charger has packed in for some reason. Link to comment Share on other sites More sharing options...
G+_Wayne Morgan Posted April 14, 2015 Share Posted April 14, 2015 Try a different set of leads from the charger to the lipo. That worked for me. About 6 months later the charger died tho. They are not the genuine article thus the cheap price. I bought another one purely because I was short of cash. Will eventually upgrade to something else. Link to comment Share on other sites More sharing options...
G+_Dan Salter Posted April 14, 2015 Author Share Posted April 14, 2015 No hologram. This is a fake I'm fairly sure. I tried different leads, same result. Can anyone recommend a good charger? Link to comment Share on other sites More sharing options...
G+_Dan Salter Posted April 14, 2015 Author Share Posted April 14, 2015 Yeah I popped it open. It looks tip top inside. No burns on the board or excess/lack of solder on the joints. The wires since it's happening on all batteries I know it's likely to be the charging unit, I just can't see anywhere that's causing the issue. Link to comment Share on other sites More sharing options...
G+_The Grimm Perspective - Posted April 19, 2015 Share Posted April 19, 2015 I've been doing a lot of research on charges as of late. AC, DC, AC/DC, single channel, multi channel, warranty, and budget? Link to comment Share on other sites More sharing options...
G+_Dan Salter Posted April 20, 2015 Author Share Posted April 20, 2015 Following up on this one. I sent the above video to Banggood and they immediately sent me a replacement. Suggests it's a known issue. Hoping the replacement lasts longer than the original. Link to comment Share on other sites More sharing options...
G+_Wayne Morgan Posted April 20, 2015 Share Posted April 20, 2015 Dan Salter that's good news. Banggood are good like that. They used to have the genuine imax b6 as well. I'd be asking for it instead and paying the difference (was around $10). Link to comment Share on other sites More sharing options...
G+_Wayne Morgan Posted April 20, 2015 Share Posted April 20, 2015 Cory Grimm what is the biggest lipo you'll be charging? How many lipos at one time do you want to charge? Personally I'd go for a DC one with the highest wattage and amperes I could afford with a power supply that will provide enough of both to run it at full capacity. Single channel as you can always get a parallel charging board. Link to comment Share on other sites More sharing options...
G+_The Grimm Perspective - Posted May 3, 2015 Share Posted May 3, 2015 Sorry Wayne Morgan, I've been disconnected from G+ and hadn't made it back here. My post should have been stated as a question for the OP. He had inquired about a good replacement. But thank you anyway. :) Link to comment Share on other sites More sharing options...
