G+_Bob Branam Posted July 22, 2017 Share Posted July 22, 2017 Does anyone know where I can find Code for WS2811 RGB LED. Thanks. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted July 22, 2017 Share Posted July 22, 2017 The Fast LED library comes to mind. And if I remember correctly, some light strips are out of order - like RBG or BRG. Hopefully someone with more experience can share advice. Link to comment Share on other sites More sharing options...
G+_Bob Branam Posted July 22, 2017 Author Share Posted July 22, 2017 Thank you. Link to comment Share on other sites More sharing options...
G+_Michael Beasley Posted July 22, 2017 Share Posted July 22, 2017 fastLED has a group FastLED Users they post projects and code with links not sure what electronic board or software you are using but here is arduino and fastled https://www.arduino.cc/ for downloading their software/install 1 if your looking for fastLED in arduino software click File/examples/fastLED you should see some demos 2 if it is not installed Sketch/include library/manage libraries library manager will pop up , in the search box search type fastLED and install it and back to 1 github can be used to find code and youtube sometimes in (show more ) has links adafruit has code/projects /videos and google can get you lost for hours searching :) Hope this is a Help! Link to comment Share on other sites More sharing options...
G+_Bob Branam Posted July 22, 2017 Author Share Posted July 22, 2017 Wow, thanks for the info. This will keep me busy for a while. Thank you. Link to comment Share on other sites More sharing options...
