Greeting looking for ideas about weird problem
G+_Arcturus Lancaster
Greeting looking for ideas about weird problem . Something weird happening on my network. Causing video playback to pause and then resume at the next key frame. Video files live on freenas server. Playback on win 7 media player classic. Computers are wired on gigE connection. Media computer has a spike in traffic just at the pause. Has gotten to every 5 min or so now. ?
Edit: seems to only happen with older low bitrate files. New content (720p+) does not seem to have this issue. Could it be buffering enough for something to time out?
Interesting problem. Perhaps there are some issues with one particular codec? Try with standard windows media player and Classic media player and vlc. The curious thing is that your HD content works fine, try to find the main different between the files: resolution, bit rate, codec etc. and if you can try to disconnect all the other machines on you network except your server and main computer and see if that helps. Also it cud be that your switch/Ethernet-cables are getting a bad connections, I think freenas has an overview I the web interface that shows you what link speed your server has.
Good luck =)
Mikael Eidsvaag ko so is divx codec. and have hickup on my mint machine. playing with totem.  so this leads me back to thinking the nas is doing something.
don't thing it is a damaged file. when i skip to just before the pause it does not happen again. damaged file should glitch same place every time.
Ok, so I am not an expert on freenas. But what can help is that you “produce” an error and then poste all the pictures from the Report sections on freenas’s web interface. And perhaps someone can figure it out. In addition, freenas has their own google+ site so maybe you can get more help form them =).
Also what are the specs on the server. some of the newer versions of Freenas needs better components.
