G+_Rud Dog Posted January 18, 2015 Share Posted January 18, 2015 Hey all, have a WD series lan drive with their multi-device access software installed. Is there software that can be installed on the WD cloud drive that will serve movies or do I have to buy something like the Synology NAS drive? Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted January 18, 2015 Share Posted January 18, 2015 Is it connected to a computer or the network? If computer, you will need to set ip up for sharing. If its connected to the LAN then it should be pretty straight forward. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted January 18, 2015 Share Posted January 18, 2015 But a plug for the Synology NAS's. I love mine. Nice interface (plus SSH/Telnet for the geek in me) Its running a RADIUS, EMAIL, DHCP, DNS, TFTP, SysLog, & PLEX servers and bittorrent client here. They claim all their devices run the same OS, from lowest to highest. Looking to get another to spread the load. Link to comment Share on other sites More sharing options...
G+_Jeff Brand Posted January 18, 2015 Share Posted January 18, 2015 If it's a NAS then it should already serve the files over DLNA/UPnP or Windows file sharing - within the network. Also, slightly older WD NAS models had a hidden but stock feature to unlock SSH access. If that still exists you can definitely start to tinker. The real question is what you mean by "serve." I'm in the process of evaluating a Buffalo NAS - so far I'm loving the throughput but haven't taken the extra step to get shell access and start adding packages through the NSLU2 project. Link to comment Share on other sites More sharing options...
G+_Jason Miles (SmoothBass Posted January 19, 2015 Share Posted January 19, 2015 The WD NAS devices have a media server built in thru DLNA. You have to turn it on in the settings as its not on by default. It has iTunes server ability as well. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted January 19, 2015 Author Share Posted January 19, 2015 Thanks Jason, will see about finding the how -to-turn-on function Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted January 25, 2015 Author Share Posted January 25, 2015 Jason Miles Found the switch to turn on DLNA, how does one watch from flat-screen TV is here an app i have to load onto my TV or better yet is there an app I load on my Tivo to assess the videos on my WDmycloud? Link to comment Share on other sites More sharing options...
G+_Jason Miles (SmoothBass Posted January 25, 2015 Share Posted January 25, 2015 Rudy Trujillo? there's no application needed for your TV if supports DLNA streaming. My Samsung TV sees everything automatically once I turned on the setting. Link to comment Share on other sites More sharing options...
G+_Jason Miles (SmoothBass Posted January 25, 2015 Share Posted January 25, 2015 Rudy Trujillo? I use localcast on my android phone to stream things from the WD. to all of my streaming media devices. Apple TV, ChromeCast ect. Works great. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted January 25, 2015 Author Share Posted January 25, 2015 As a test loaded localcast, install was flawless located my WDmycloud from listing opened and I see Folders at the top but no folders are displayed. Don't know what is required on the WDmycloud side like creating permissions or folders can you help? Link to comment Share on other sites More sharing options...
