G+_Rud Dog Posted January 22, 2015 Share Posted January 22, 2015 Recently upgraded my router and switch to Gb speed and cables but ran in to a possible gotcha moment. While roughing it all in the cable from rooms to switch were Cat-6. Since I was linking my modem over to a router and from there another switch, to pick up the extra cables the 4 port router would not handle, I caught myself using a short cable for neatness between the switch and router. It was then that I thought what is the difference between Cat-6 and Cat-5 the latter my older setup. Are the cables physically wired differently? Will this short jump between my router and 8 port switch affect the Gb transfer rate. Summing up just what kind of affect does mixing Cat-6 and Cat-5 cables have on a upgraded Cat-6 environment? Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted January 22, 2015 Share Posted January 22, 2015 Wiring is basically the same - kinda. Gb uses more/all of the wires then 10/100 (why you can't do PoE on Gb, nor bundle voice and data) The diff in Cat5 and 6 is going to be in the impedence, inductance of the cable. The twisting scheduled of the pair may be different too, I haven't looked that far into it. try a 5e. Link to comment Share on other sites More sharing options...
G+_Akira Yamanita Posted January 23, 2015 Share Posted January 23, 2015 A short Cat 5 cable will probably work fine even at GB speed. Cat 5e will work at 1 Gb. Link to comment Share on other sites More sharing options...
G+_Joe Phelps Posted January 23, 2015 Share Posted January 23, 2015 Cat 5 can do gigabit just fine. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 23, 2015 Share Posted January 23, 2015 Both Cat-5e and Cat-6 use 4 twisted pairs of wire. The primary difference is that Cat-6 wire pairs have a tighter twist to them, though most Cat-6 cables also have a plastic divider in the middle of those 4 pairs. Cat-6 cables is rated at 1000 Mbps speeds up to ~330 FT and Cat-5 is rated at 100 Mbps at the same distance. In testing, a Cat-5e certified cable can handle around 300 Mbps at 330 FT and 800 Mbps (effectively Gigabit) at 100 FT — if my memory serves me correctly. That said, a short Cat-5e cable should have little to no problems with a 1000 Mbps load. If you're interested in switching those cables out though, Monoprice probably has short Cat-6+ pretty cheap. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted January 23, 2015 Author Share Posted January 23, 2015 Thanks everyone. Noted one comment that left me asking yet another question. Eddie Foy you say in your response "why you can't do PoE on Gb" yet I thought I saw POE Gb switches on sale did I read the add wrong? Again thanks for the input. Link to comment Share on other sites More sharing options...
G+_Mat Murdock Posted January 24, 2015 Share Posted January 24, 2015 You can do POE on a GB connection just fine. I do it all the time. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 24, 2015 Share Posted January 24, 2015 Yeah, I believe no PoE with Gigabit is a common misconception based on the way PoE works with 100-TX and 10-TX. Someone please correct me if I'm wrong, but with twisted pair cable you traditionally had 10/100-T and 10/100-TX - the difference being that T uses all 4 pairs for transmission and TX only uses 2 pairs (most devices were 100-TX even if they just said 100-T). Since only 2 pairs were used, the other 2 pairs are used to carry power. Now, I haven't looked into how PoE works with 1000 base-T since all 4 pairs are used, but I imagine it has something to do with the differential signalling used to actually transmit data. Even though BR/BR-W is carrying data, it only needs a slightly different voltage between those to actually transmit data and it doesn't matter if that's 0v and 5v or 12v and 17v. Again, that's a complete guess, but I think it's close to how it would work. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted January 24, 2015 Author Share Posted January 24, 2015 Plan on placing a Gb/POE switch in the garage from where I can run my cameras but want to make sure this is not an issue. Thanks to everyone for their input. Link to comment Share on other sites More sharing options...
