How much WiFi is to much for home load
G+_Rud Dog
I shared this a few weeks ago, but here's what it's like at my house: https://goo.gl/photos/oEfbYdT2HHjswJAe9
WiFi (2.4GHz in particular) gets congested because there are 11 channels (in the US) to use, but the wireless signal from each channel overlaps the channels around it. To use only non-overlapping channels, you can divide it a few ways, but the most you'll get is 3 non-overlapping channels (1, 6, 11). Unfortunately, most routers don't take advantage of this and they'll auto assign all the others as well which hurts everyone (channel 4 interferes with 1 and 6, for example). Since everyone wants the strongest signal to drown out their neighbor's WiFi, it's not uncommon to have several neighborhood WiFis accessible in your house.
Rudy Trujillo?? It depends on where you live. If you have lots of space between you and your neighbors, your 2.4 range is probably cleaner. If you are in a high population density area your 2.4 is probably is probably saturated. Wifi analyzer will help you determine that.
Also if you have multiple APs in your network, make sure they are NOT using the same channel. Also make sure you are not using overlapping channels in the 2.4 range either. ?
