Playing around with a 9 8 DC volt motor removed from a drill motor
G+_Rud Dog
Playing around with a 9.8 DC volt motor removed from a drill motor.
The brick I found in my junk box is rated at 12VDC 2.5 AMPs.
Using the variable trigger from the parts acquired when the drill motor was disassembled I find the motor cuts out at certain point around 3.2 AMPS. Now I have lots of 12VDC bricks in my junk box and was wondering can I use them in a configuration similar to batteries. By that I mean can the bricks be placed in parallel and function or blow up in my face?
Might say on the label.  O'scope might show the HF ripple of a switching while 'freewheeling'
Also the efficiency would give some idea, linears, while being 'clean' are wasteful and toss off more heat.   Measuring the input current vs output would be an indication.
