Labview Ran across a project where Labview was used in conjunction with the Raspberry Pi3 and...
G+_Rud Dog
Labview.
Ran across a project where Labview was used in conjunction with the Raspberry Pi3 and it got my attention.
However It would be nice to find a video, which I am currently searching for, demonstrating the basic setup of the hardware connection and needed software install. The ones found so far are just beyond this part of the setup.
P.S.
Even an open source equivalent would be great.
Thanks.
For those wondering, LabVIEW is used to help automate interactions between sensors, controllers, and devices, with a focus on "engineering" projects. (I use quotes because the maker is the heart of the engineer, in my mind. The product seems to market itself to professionals, but isn't limited so.)
I found an instructable with YouTube links for segments of the project.
Also, it looks like your set up a pi with Raspbian, and get it on the network. Install LabVIEW in your PC, which has a module to remote into the pi and set up its hooks and whatnot on top of Raspbian.
I hope this helps.
instructables.com - Getting Started with the Raspberry Pi 2 (LabVIEW)
