USB hubs It has been my assumption USB hubs provide data transfer and power on each port Now wh...
G+_Rud Dog
USB hubs
It has been my assumption USB hubs provide data transfer and power on each port. Now while trying to upgrade my 2.0 whether it be 4 port or 7 port finding out I know nozing about ports on USB Hubs.
First off if it is a charging port then no data transfer period.
Also not sure what kind of power the other non-charging ports supply cause was under the impression all other ports were low power and data transfer ports. But can't find how much these non-charging-port ports supply?
Yes, the USB charge dr. is an excellent piece to have to monitor charging of anything. I got mine from Aliexpress for a few $ and have one with small display data < https://plus.google.com/photos/photo/110690680341063574122/6233870760682577714?iem=4&gpawv=1&hl=en >and one with large display data and dual output ports too. The cumulative power used recorded is nice to actually know what battery capacity really is.
Many to choose from Aliexpress:
https://m.aliexpress.com/w/wholesale-usb+doctor.html#/
USB hubs can be powered externally or just get their power from the USB port on the host.
I believe the USB 2.0 spec is 500mA for data ports, but it shouldn't be limited to that. For USB 3.0, that should be a 900mA limit. I was also thinking most phones were designed to only draw a small amount of power when plugged into a data connection - so they don't draw more current than the computer can comfortably provide and assuming you're plugging in to transfer data instead of power.
If your hub has a "charging" port, there is probably no data lines connected and the phone will pull the full current availability - usually 1A for cheap chargers and up to 3A for nicer chargers (I think QC3.0 supports 5V 3A or up to 20V at lower amps).
That's about the extent of my USB knowledge (some facts may be off). One of those USB testers would be a great way to research - though may give an incomplete test if the data pins aren't connected through the device.
Surprised the makers of these devices don't' take into account the older sight impaired hobbyist. It would great if the screen was a bit larger like the one on the older keyboarded Blackberry. Guess I am gonna have to pick one with the largest font.
Rud Dog I have a bunch of streaming boxes, picked up a FireTV Stick on sale. It came with a 1amp adapter, and the USB port on my RokuTV was rated at 1/2 amp, so I was hesitant to run it too long.
This device showed me it pulled less that 1/3 amp when streaming from Amazon or Youtube. No worries.
