G+_Brandon Ingli Posted June 12, 2017 Share Posted June 12, 2017 Is it possible to send 5V from a raspberry pi over Cat 5e cable to some vibration sensors? What are the voltage/current limits on each cable? Link to comment Share on other sites More sharing options...
G+_James Hughes Posted June 12, 2017 Share Posted June 12, 2017 Can you do POE? No Pi needed. Link to comment Share on other sites More sharing options...
G+_Ben Tyger Posted June 13, 2017 Share Posted June 13, 2017 I don't believe the Ethernet interface of any of the Pis supports PoE. Also considering the the Ethernet adapter is USB 2.0 based there problaby isn't much power there. Link to comment Share on other sites More sharing options...
G+_Joe Valasko Posted June 14, 2017 Share Posted June 14, 2017 It is possible to use Ethernet Cabling to transmit power but there are limitations such as voltage drop, current demand, and wire gauge that need to be considered. If your Ethernet is less than Gigabit then passive or active Power Over Ethernet (POE) is possible. If you are dealing with relatively short runs of Ethernet you could consider the following. One example of such adapters is aliexpress.com - Hot POE Cable Passive Power Over Ethernet Adapter Cable POE Splitter Injector Power Supply Module 12-48v For IP Camera You should know the AWG wire size of the Ethernet (which can vary by vendor and quality), length of Ethernet, Voltage, and Current demand for your devices. You have to watch the voltage drop which is one of the reasons most POE is 48 volts. A simple Ohm's law calculation is necessary to ensure your device is able to receive the minimum voltage and current you require. Link to comment Share on other sites More sharing options...
