So, Been following along with the stepper motor builds and I didn 't have access to a 3D printer...
So, Been following along with the stepper motor builds and I didn't have access to a 3D printer so I cobbled together a base for the stepper motor setup and mounted my gopro to it. Set the delay to 1 second and tried it out today. The clouds didn't look like they were moving at all, I thought it came out pretty good. Can wait to add another axis to this.
I used the UBEC and stepper motor controller directly from the build. I did not have to swap any pins.
Since I didn't have a 3D printer, I knew I had to mount the motor. I took a piece of wood, a Forster bit and a little time and came up with this. The square piece of plywood has a 5mm hole in the center for the motor shaft and a 1/4 countersunk hole to mount the gopro mount. This is NOT it's final form. I know this is probably one of the jankiest setups you have probably ever seen, but hey... it works....:-) it it took me about 15 min to build with a drill press.
https://goo.gl/photos/ZkcKLfzhwgAKqTph9
  • 3 weeks later...
