Heatshrink question(s): My Bose earbuds have a split in the insulation between the jack and the ...
G+_Will Pherigo
Heatshrink question(s): My Bose earbuds have a split in the insulation between the jack and the reinforced area where it goes to each earbud.
The connectors are too wide to slip heatshrink tubing over. Do I just slit the tubing and then heatshrink it to cover the split insulation?
I tried using a hair drier to shrink the tubing, but it seems underpowered. Correct?
Thanks.
