Been choosing parts for a modified version of the KH 250 FPV build (will be a 260 FPV with the fr...
G+_Erik Ellsinger
Been choosing parts for a modified version of the KH 250 FPV build (will be a 260 FPV with the frame I've choosen) and I was wondering if someone could take a look at my part list to see if the parts I have choosen are good or if I should change something?
Here is my list:
Frame: HobbyKing FPV260 Up-Swept
http://hobbyking.com/hobbyking/store/__75953__HobbyKing_FPV260_Up_Swept_Mini_Quad_Copter_KIT_.html
HobbyKing FPV250 Racer Long Frame Upgrade kit
http://hobbyking.com/hobbyking/store/__56663__HobbyKing_FPV250_Racer_Long_Frame_Upgrade_kit.html
Motor: RTF Mini Motor X2208 2300KV
http://www.readytoflyquads.com/rtf-mini-motor-x2208-2300kv
ESC: F-30A Fire Red series SimonK
http://www.readytoflyquads.com/f-30a-fire-red-normal-esc-with-rapidesc-fw-for-multirotor
Props: HQ Prop 6x3 Fiberglass Composite Prop
http://www.readytoflyquads.com/hq-prop-6x3-green-carbon-composite-prop
Flight controller: Flip MWC Flight Controller 1.5
http://www.readytoflyquads.com/flip-mwc-flight-controller
Battery: ZIPPY Flightmax 2800mAh 4S1P 30C
http://hobbyking.com/hobbyking/store/__14058__ZIPPY_Flightmax_2800mAh_4S1P_30C.html
And some other things you need:
Mini Power Distribution Board 2oz copper
http://www.readytoflyquads.com/mini-power-distribution-board
Male XT60 Plus 12 Awg Wire:
http://www.readytoflyquads.com/xt60-female-plug-plus-xt60-12-awg
Silicone Wire HIgh Voltage - 12 or 14 AWG:
http://www.readytoflyquads.com/silicone-wire-14-12-awg-one-meter-black-one-meter-red
Vktech Gold-plated Bullet Connector:
http://www.amazon.com/Vktech-Gold-plated-Bullet-Connector-Battery/dp/B00DGL1T1O/ref=lh_ni_t?ie=UTF8&psc=1&smid=A1EX7LU0M6LM21
What do you guys think about that build?
  • 1 month later...
My first thought is that you might be dragging up too much battery. 2800 mAh is a bit beefy. I have been flying some things in this size recently and a 1500 will give you a 5 -6 minutes of good flight time, and you can really fly it like you stole it
