G+_Erik Ellsinger Posted July 20, 2015 Share Posted July 20, 2015 Want to put some red and green led strips on my quad, for example these: http://www.readytoflyquads.com/lighting-strip-green That led strip require 12V, does someone know of a converter I can put on my quad that converts the 14,8V I get from my Lipo to 12V? Link to comment Share on other sites More sharing options...
G+_Taylor Graham Posted July 20, 2015 Share Posted July 20, 2015 you're flying 4 cell? On your KH250? A lot of the rc shops should have voltage regulators for flying FPV stuff on 4 cell. Check for one that will get you to 12v (a lot might be 9v). Or just make your own. Link to comment Share on other sites More sharing options...
G+_Erik Ellsinger Posted July 20, 2015 Author Share Posted July 20, 2015 Yes, but it's a modified version of the KH250. Been looking at the readytoflyquads site, what do you think about this one? http://www.readytoflyquads.com/dc-to-dc-mini-step-down-adjustable Their site always seem to be so slow for me so it's hard to browse it. Link to comment Share on other sites More sharing options...
G+_Taylor Graham Posted July 20, 2015 Share Posted July 20, 2015 Looks perfect to me. And its super cheap. At that price i wouldnt bother making one yourself. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted July 20, 2015 Share Posted July 20, 2015 Most 12v strips will handle 14.8 volts just fine. :)/#testfirst Link to comment Share on other sites More sharing options...
G+_Erik Ellsinger Posted July 20, 2015 Author Share Posted July 20, 2015 Think I will try both ways, with voltage regulator and without Link to comment Share on other sites More sharing options...
G+_Black Merc Posted July 20, 2015 Share Posted July 20, 2015 Fr. Robert Ballecer, SJ agree... most have a wide voltage range, 8-15v, being that more voltage = brighter, till over max = dead Link to comment Share on other sites More sharing options...
G+_Aye Mossum Posted July 21, 2015 Share Posted July 21, 2015 Resistors will bring down the current a bit. Just apply Ohm's law V=I•R. Check the resistance of your LED strip, determine the current that you would get at 12V, then add resistance to keep that current level when you jump up to 14.8. Link to comment Share on other sites More sharing options...
