G+_Erik Ellsinger Posted May 13, 2016 Share Posted May 13, 2016 Does anyone have any tips on how to best protect against power surges over my TV antenna cable? I've looked at something like this: http://www.amazon.com/Parts-Express-Cable-Coaxial-Protector/dp/B0002KR7EK/ref=sr_1_10?ie=UTF8&qid=1463175628&sr=8-10&keywords=surge+protector+tv But is that really enough? I'm also not completely clear on how it works, my guess is it cuts the connection if it senses a power surges? http://www.amazon.com/Parts-Express-Cable-Coaxial-Protector/dp/B0002KR7EK/ref=sr_1_10?ie=UTF8&qid=1463175628&sr=8-10&keywords=surge+protector+tv Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted May 13, 2016 Share Posted May 13, 2016 Using cable TV or Antenna and worried about lightning, static build-up, and the such? I think cable TV is a 1Vpp, so anything much over that would get snubbed. (forgot the name but its a little fancy gas filled zener like diode/device) Now if you also have a cable modem, do consider every connection and device drops the signal. Every 3dB is the is 1/2 the signal. Link to comment Share on other sites More sharing options...
G+_Erik Ellsinger Posted May 14, 2016 Author Share Posted May 14, 2016 If I could use fiber I would already be but that is not an option. I have a UPS but it doesn't have a coax connector, I would have bought one that had if I could but I can't find anyone in Sweden. So that is why I'm looking at this alternative since the coax is like a backdoor for a lightning strike into my otherwise protected system. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted May 15, 2016 Share Posted May 15, 2016 For lightning I use one of these on my 20 meter dipole which is hanging 30 feet in the air. Good to 500MHz. http://tinyurl.com/zzeo7wz Link to comment Share on other sites More sharing options...
