G+_Jason Perry Posted November 8, 2014 Share Posted November 8, 2014 I have quad questions for those who are geeking out with them right now. The props on some quads such as the Parrot AR drone sit at a slight downward angle, is there a benefit to this or is it just marketing? Link to comment Share on other sites More sharing options...
G+_Ryan Parks Posted November 9, 2014 Share Posted November 9, 2014 I would say no. For stability something with a slow fly prop and motors in the 750-1000kv range are most efficient and stable. Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted November 9, 2014 Share Posted November 9, 2014 What do you mean by "a slight downward angle"? If the props had no angle on them, the would not generate any thrust, couldn't even use them for a fan! Link to comment Share on other sites More sharing options...
G+_Jason Perry Posted November 9, 2014 Author Share Posted November 9, 2014 Travis Hershberger if you look at most quads the arms holding the props come straight out from the centre of the frame so if you put it on a table it would sit flat. On the Parrot AR drone there is a slight angle so only the 4 tips would touch the table and there would be a small air space between the centre of the quad and the table Link to comment Share on other sites More sharing options...
G+_Jason Perry Posted November 11, 2014 Author Share Posted November 11, 2014 More a question out of is that a desirable feature or a gimmick. I am waiting for Christmas to see if I get a trainer. And if not I'll have something cheap for the new year that way I don't cry when I run it into a wall. Link to comment Share on other sites More sharing options...
