I need some Mobile Data Advice
G+_Jaz DeWills
I need some Mobile Data Advice.
I am considering switching to 7-Eleven's SpeakOut™ as a mobile data provider. They offer $10/mo unlimited data (2GB Fair Usage). I have read some reviews and it looks like they only allow traffic through port 80.
Here are my 2 questions:
1: If I set up a proxy will I be able to get around this port 80 restriction?
2: What kind of speeds will I be looking at? I'm not sure of the initial speed of their network, and I know that a proxy will only slow things down further.
I would like to do some web development in remote areas this summer (camping/cottage) so I will need access to FTP/SHH
Assuming that they do restrict traffic to just port 80, this is how you work around it:
1.) Build a server with SSHd running on port 80
2.) SSH from your client machine to the server on port 80 and set up a SOCKS proxy.
3.) Tell all of your client apps to use the SOCKS proxy on localhost.
You would: ssh -p 80 -D 9999 username@hostname
And then tell your apps to use the SOCKS proxy on 127.0.0.1, port 9999.
