I am thinking of making an anemometer out of a 120mm PC fan
G+_Jason Perry
I'm not sure if all fans would work as well but I've never tested since some are variable, 3 or single speed fans. Plus as Robert mentioned you would need a lot of force. You would only be able to get readings from strong winds and would have to figure out how fast the fan spins vs how hard the wind is blowing. There also not as free spinning as typical wind sensors. I did a search and found an arduino dedicated wind seneor but it is $70. If you find a way to Calibrate it maybe try making a free spinning anemometer or by one if those wind spinner things that sit on the roof and hack some type of speed/rotation sensor of some kind to it. Still requires you to Calibrate it but it would work better then a PC fan.
FYI I found an instructable about making one. I didn't read it through but it may help you out.
http://www.instructables.com/id/Anemometer-on-the-cheap/?ALLSTEPS
