G+_Jason Perry Posted July 25, 2016 Share Posted July 25, 2016 So I think i may have figured out my earlier problem with Synergy. If I go to the configure server button I thought was a dead end and drag a new screen onto the grid I am given options to edit the new screens settings. I am guessing if I name the screen the clients name and for good measure add the clients name as an alias it should work. The first pic is from the computer I am trying to set up the others are from a different computer I am using to find what I am missing. Link to comment Share on other sites More sharing options...
G+_610GARAGE Posted July 25, 2016 Share Posted July 25, 2016 It's been awhile since I setup synergy, but I think it's failing to connect. :) From captain obvious. The first thing I would try is disabling the firewall just to see if it is being blocked. If that doesn't effect it, check ip address and username/password. Unfortunately that's all I can think of. I have been using another program called input director. Its not as finished as synergy but I think it works out better. Just incase synergy proves fruitless. Link to comment Share on other sites More sharing options...
