Fun project
G+_Jason Perry
Fun project. I would like to make a LoRa gateway. Here we s my issue, after shipping the radio for the gateway is €200. Sorry really want to do it but that works out to $280CAD. Does anyone know a cheaper way to get this done?
When I say cheaper my max price everything in is $150USD OR €145.
https://www.thethingsnetwork.org/#!
I am a bit confused by the significant cost difference. You can purchase an Adafruit Feather 32u4 RFM96 LoRa Radio - 433MHz
PRODUCT ID: 3079
for $34.95US from adafruit.com - Adafruit Industries, Unique & fun DIY electronics and kits
I can't see the CAD costing that much more but maybe I am naive.
https://www.adafruit.com/products/3079
To follow up on this post. The cheap gateway will only do one channel and spreading factor. This is good for up to 20 sensors that are locked into the same specs as the gateway.
The spreading factor determines the data rate, as the data rate goes up the distance goes down. Using a cheap radio you have to choose what compromises you are willing to make.
If anyone here is interested in this topic I recommend checking g out Andreas Spiess? YouTube channel
