Is there a way to put a networked printer on 2 networks?
G+_Jason Perry
My issue is some of the computers in a network I maintain connect to a VPN, and this is creating printer problems.
My current train of thought is to get a mini or micro class computer with 3 or more network ports, have it connect to each network and pass the traffic to a third network the printer is on. Are there setups like this currently out there?
Issues
I doubt I can keep the VPN alive for an extended period of time.
I don't know if I can get a static IP on the VPN
Jason Perry Probably need a network diagram of what is going on.
Yes you can bring 3 networks to a computer then run windows Printer sharing.
The downside is if that computer gets owned so do the 3 networks. I imagine they are separate for a reason.
Have a business grade Epson I picked up for $75 lol. Might be easiest way to go other than cloud print.
It seems like you should be able to put a router between the two networks LAN port connected to the side with the printer and WAN port connected to the other network. Turn off DHCP, set a static IP on both WAN and LAN ports, and port forward to the printer. Computers on the second network would point to the new router's IP. Since it's all internal networks, I would guess you could even DMZ to the printer?
I'm not sure what ports you would need. And if I'm wrong on this idea, someone please let me know ?
