G+_William Shimmin Posted May 25, 2016 Share Posted May 25, 2016 A few weeks ago you ran a segment on creating a garage parking sensor using an Arduino and I've been wondering if I could do something similar with a Raspberry Pi Zero. After much experimenting, here it is. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted May 25, 2016 Share Posted May 25, 2016 The Pi Zero is electronic though. Brilliant! Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted May 25, 2016 Share Posted May 25, 2016 No, you could probably out the Pi Zero inside a tennis ball and hook up a gyroscope to sense the impact. The string would have to be replaced with a USB cable. But this design is still way easier! Link to comment Share on other sites More sharing options...
G+_Julian Divett Posted May 25, 2016 Share Posted May 25, 2016 you could save on the string and just listen for the crunch Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted May 25, 2016 Share Posted May 25, 2016 Been pondering one myself. One marker for deep to open rear hatch, and a shallow one to get around the front. Most of the ones I see, seem to miss a obvious powering method: use the overhead light bulb. Its only on for a few minutes. Just use a laser pointer. No need to bring a CPU into the mix. Link to comment Share on other sites More sharing options...
G+_Phillip Clarke Posted May 26, 2016 Share Posted May 26, 2016 LOL Link to comment Share on other sites More sharing options...
G+_Peter Hanse Posted May 27, 2016 Share Posted May 27, 2016 Love new uses for technology LOL Link to comment Share on other sites More sharing options...
G+_Jason Marsh Posted May 27, 2016 Share Posted May 27, 2016 You're all missing the point here. The problem is that the Pi Zero and Arduino cannot be configured for parking right-hand drive vehicles due to proprietary software being locked to left-hand drive configs. Whole nations are considering moving to LHD to solve this simple problem. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted May 27, 2016 Share Posted May 27, 2016 It needs to be cloud based with its own twitter feed. Load cells in the floor so I'll know in advance if I need gas. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted May 27, 2016 Share Posted May 27, 2016 The load cells sounds like a cool design, but I'm not sure it would work for me. Depending on when we cleaned out the car last, there could be enough toys, trash, strollers... to make it think we've got a full tank - or more. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted May 27, 2016 Share Posted May 27, 2016 ultrasound aimed up at the tank then. be that way! :P Link to comment Share on other sites More sharing options...
G+_Joe Valasko Posted June 4, 2016 Share Posted June 4, 2016 Awesome project. Made me chuckle! Thanks! Link to comment Share on other sites More sharing options...
