G+_Nathan Sikita Posted August 9, 2015 Share Posted August 9, 2015 So I have a problem I'm hoping someone can help me with. I was at the part on building my KH250 where I need to set the ESC, when I plugged the battery in it made a popping sound and then nothing happened. I decided to check the voltage and everything with my voltmeter and find out that in my 3 cell lipo one cell is now completely missing and it shows 0 charge total but but each individual cell has a charge. I don't know what i did, not sure if the battery was just defective or I screwed up somewhere with the soldering or connection (all the power wires are going to their respective color coded opposite) please help!!! Link to comment Share on other sites More sharing options...
G+_Michael Heinz Posted August 9, 2015 Share Posted August 9, 2015 Two possibilities come to mind - either yes, you had a bad battery or, yes, you somehow have a short in your soldering. Was this the first time applying power? The first thing I would check is for a short - set your multi-meter for resistance/continuity mode and touch the leads to the battery terminals of your quad - if the multimeter shows no resistance then you've got a short. Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 9, 2015 Author Share Posted August 9, 2015 This was my first time attempting power Link to comment Share on other sites More sharing options...
G+_Michael Heinz Posted August 9, 2015 Share Posted August 9, 2015 Did you try the multi-meter? Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 10, 2015 Author Share Posted August 10, 2015 yeah and it showed up no resistance, so now I have to find where the short is Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 11, 2015 Author Share Posted August 11, 2015 where is it most likely that the short would be, and how would I go about looking for the short? is it mostly likely a bad soldering job on the quad's pdb? this is my first time soldering so I'm not sure if I might have just done a poor job on it. Link to comment Share on other sites More sharing options...
