G+_Nathan Sikita Posted August 28, 2015 Share Posted August 28, 2015 so I was working on finishing up my KH250 quad when I came upon a snag, when I connect a battery or usb to my flight controller at level the blue light won't appear, but if I tilt it in any other direction it starts flashing like it so. Also when I try to attach it to my computer and run it with MultiWii it doesn't give me the option to connect. Is there a way to fix this or do I need to get a new flight controller? Link to comment Share on other sites More sharing options...
G+_Steve Prior Posted August 28, 2015 Share Posted August 28, 2015 I'd say disconnect the Flip from everything else and only plug it in via USB and see if you can connect, that will tell you if your wiring is messing up something. Link to comment Share on other sites More sharing options...
G+_nn tt Posted August 28, 2015 Share Posted August 28, 2015 Here is a link to all the info you will need to get it going. Read all of it. http://www.readytoflyquads.com/the-rtf-wiki Here is the outline of what you can do Make sure the driver is install Connect the FC to computer Check your hardware in Windows to make sure it is showing up correctly Make sure to run v2.3 of your multiwii software of choice. V2.2 will corrupt your settings on the FC when you write setting out. You should follow all the steps before flying. The min max and center values on your transmitter must be set correctly for your FC to work. Have fun. Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 Steve Prior I did do that and my FC still won't connect to the MultiWii program or the computer in general Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 nn tt tried all of this and still nothing has changed Link to comment Share on other sites More sharing options...
G+_nn tt Posted August 28, 2015 Share Posted August 28, 2015 Try another computer. Try a different USB cable. Link to comment Share on other sites More sharing options...
G+_Steve Prior Posted August 28, 2015 Share Posted August 28, 2015 When you plug into the computer do you see an extra serial port in device manager? What operating system is your computer running? Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 I'm running win7 and no another serial port doesn't show up Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 nn tt I've done both of these and it still doesn't work Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 this is the problem I'm having, I did look and saw that the drivers won't install and need a fix maybe Link to comment Share on other sites More sharing options...
G+_Steve Prior Posted August 28, 2015 Share Posted August 28, 2015 My instinct is saying device driver issue. In device manager do you have any unidentified devices showing up when the Flip is connected? The Flip wiki page says to use the 32 bit version even if you are running Windows 64bit (which you probably are if you're running Windows 7). But this has to be my last guess of the night. Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 so I'm pretty sure now that it's a driver problem.....so how can I fix it? Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 cool beans, thanks Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 Wayne Hobbins This build has been such a pain, one problem would come up and I'd fix it then another would rear its head...hope this is the last fix I need Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 28, 2015 Author Share Posted August 28, 2015 thanks for all the help, hopefully this solves the problem and nothing else goes wrong Link to comment Share on other sites More sharing options...
G+_Steve Prior Posted August 29, 2015 Share Posted August 29, 2015 Sounds like you fixed it - what did the trick? Link to comment Share on other sites More sharing options...
G+_Nathan Sikita Posted August 29, 2015 Author Share Posted August 29, 2015 it was the USBs Link to comment Share on other sites More sharing options...
