G+_Mark Cryan Posted May 11, 2013 Share Posted May 11, 2013 Hi everybody need some advice please. Watched know How 43 ( Truecrypt ) Installed on Osx 10.8.3 fine. When I open I just get an error message. Anybody else have problems with ML 10.8.3. Any advice would be much appreciated. By the way it's a hackintosh. Link to comment Share on other sites More sharing options...
G+_Mark Cryan Posted May 11, 2013 Author Share Posted May 11, 2013 Application Specific Information: dyld: launch, loading dependent libraries Dyld Error Message: Library not loaded: /usr/local/lib/libfuse.2.dylib Referenced from: /Applications/TrueCrypt.app/Contents/MacOS/TrueCrypt Reason: no suitable image found. Did find: /usr/local/lib/libfuse.2.dylib: stat() failed with errno=13 /usr/local/lib/libfuse.2.dylib: stat() failed with errno=13 Link to comment Share on other sites More sharing options...
G+_Linvydas L Posted May 12, 2013 Share Posted May 12, 2013 Looks like you have to install fuse4x, according to this bug report: https://github.com/fuse4x/fuse4x/issues/6 Link to comment Share on other sites More sharing options...
G+_Mark Cryan Posted May 12, 2013 Author Share Posted May 12, 2013 Thank you for the advice. I will give it a try :) Link to comment Share on other sites More sharing options...
