G+_Gary Cheney Posted December 31, 2015 Share Posted December 31, 2015 I received a raspberry pi 2 for Christmas, yea, only problem is I can't get sounds through hdmi. Link to comment Share on other sites More sharing options...
G+_Jason Perry Posted December 31, 2015 Share Posted December 31, 2015 Bet you cat have just one. :) Link to comment Share on other sites More sharing options...
G+_610GARAGE Posted December 31, 2015 Share Posted December 31, 2015 Have you looked at this: https://www.raspberrypi.org/documentation/configuration/audio-config.md You need to tell the pi to send audio out of hdmi. If you don't, it will use the analog output. Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted December 31, 2015 Author Share Posted December 31, 2015 Yes, I tried but still no luck, the weird thing is that I have no sound through analog output either. Link to comment Share on other sites More sharing options...
G+_610GARAGE Posted December 31, 2015 Share Posted December 31, 2015 sounds like.... that was unintentional, it's configured to a nonexistent device. But how to check/change that, I am unsure. Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted December 31, 2015 Author Share Posted December 31, 2015 Apparently this is not a new problem, the only thing that is weird is the noobs insert at the end of the configuration file. I am unsure of the control character ^m which proceeds and follows the noobs insert. Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted December 31, 2015 Author Share Posted December 31, 2015 I am not a programmer and the last time I had to write configuration files was in the 1980's Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted December 31, 2015 Author Share Posted December 31, 2015 Also tried reloading system and it doesn't help. Link to comment Share on other sites More sharing options...
G+_David Dunn (tanker405th Posted January 1, 2016 Share Posted January 1, 2016 Out of curiosity, have you ran update and upgrade? I remember having the same problem with my model B+ when I first got it. Seems like I ended up having to install alsa-utils, but it has been quite a while (memory is a little fuzzy!). Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted January 1, 2016 Author Share Posted January 1, 2016 No but I will, thanks Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted January 9, 2016 Author Share Posted January 9, 2016 Tried update and upgrade to no avail. Ran test file recommend by raspberry website still only have sound through headphone jack. Link to comment Share on other sites More sharing options...
G+_David Dunn (tanker405th Posted January 9, 2016 Share Posted January 9, 2016 That's strange. Maybe someone with a Pi 2 can take a look at their config file for comparison, or maybe it's really defective? Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted January 9, 2016 Author Share Posted January 9, 2016 I am hoping someone else is having the same issue, I did get a replacement under warranty, same thing, but at least audio through jack. Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted January 9, 2016 Author Share Posted January 9, 2016 Thanks David Link to comment Share on other sites More sharing options...
G+_Gary Cheney Posted January 11, 2016 Author Share Posted January 11, 2016 I think I finally figured it out. I was watching twit.tv on the computer which uses the same tv as a secondary monitor, the sound of the show was coming through the hdmi input I was using for the raspberry pi 2. I believe that the tv is seeing the raspberry pi 2 as a computer input (which it is ) instead of a video input which is causing the audio to be channeled to computer input which is analog. I will continue to try to find a workaround. Thanks to all for the input. Link to comment Share on other sites More sharing options...
