Installed three decorative outdoor LED fixtures all connected to a "duel Brite " controller (on ...
G+_Mark Losinski
The dual-brightness systems are low for the 3/6/AN modes and full bright when movement is detected.
Since your LEDs are built in, I would expect that the circuit is designed with dimming in mind.
That leaves us really with only 2 possibilities I can think of... Undervoltage or defective products. Have you checked the voltage to the wires from the wall?
No. The motion sensor requires full, STABLE voltage or it will die an untimely death. Your best bet in this case is to use the motion sensors with an incandescent fixture or return them for a lamp with the feature set you are looking for.
That said, if you just want dimming capability without motion sensing, then, yes. You MAY be able to drive your current lamps with a PWM dimmer. However... your lamps may not be able to handle it, depending upon the circuit design.
There's nothing magical about dimmable LEDs. It's the driver circuit handling the switching that makes it dimmable or not. If it were me doing it, I'd tear open the enclosure on the lamp and take a hard look at the driver.
[sorry about the edit... I didn't say it right. PWM is full voltage, but inturrupted. That'll kill your motion sensor or at least make it not work right until it dies]
