Fr Robert Ballecer, SJ when do you plan to air a segment on altitude hold using the barometric...
G+_Rob Yesta
Fr. Robert Ballecer, SJ when do you plan to air a segment on altitude hold using the barometric feature of the Flip 1.5 flight controller? I know you set up a switch to turn Baro mode on but it's not that simple. You still need to do some Altitude PID tuning. You will need to take your laptop in the field or can you program using Bluetooth module and smart phone?
Fr. Robert Ballecer, SJ I set up the baro switch and did a quick test. Nice feature to have and I can't wait for your tips on tuning.  I did set it at about 10 ft and it did good keeping the quadcopter off the ground. It moved up and down about 2 ft when moving forward and back but I bet tuning will reduce that down.
