Need some router help
G+_Mark Messiha
Need some router help.
So my Netgear Nighthawk AC1900 got a little weird after flipping the breaker for that room to replace a wall plug. The 5GHz network only works now if you're standing right next to the router. It used to work great throughout the house. The wall plug replaced was not the one that the router used. The 2.4GHz network works fine but obviously doesn't have the speed that the other network had.
A few questions:
1) Did I do this by forgetting to shut off the router before flipping the breaker?
2) I've rebooted the router, factory resetted the router, and done a firmware update to no effect. Would/ could putting open source firmware fix this?
Netgear wants 90 bucks to do phone support with this thing which I'm not really ready to pay. They reimburse you if it becomes a hardware replacement thing but I'm kinda turned off by them at this point.
Thanks Know How community!
as to your question is there a difference between flipping the breaker off and having a power failure: No, it's the same effect.
I believe it is just coincidental that the router decided to start acting up after you turned the power off, then back on. Yes, sometimes electrical stuff does weird things, but in your case, I think the router is just failing.
As for $90 for phone support, what phone support do you feel you need? You've already done what a phone support person would tell you, other than send it in.
Is it in warranty? do you feel like sending it in? what will you use in the meantime?
What will they charge if you send it to them to have it checked out, and give you an estimate of repairs? Is it worth that, or would you rather just buy a new router (with a new warranty)? I would probably go with the latter.
ps. did you buy it with a credit card? sometimes CC companies will double the warranty.
How cheap was the replacement wall plug? Did you use the screw terminals(as opposed to the slide-in holes on some types)?
Reason: low quality components, and poor connections can generate noise(many forms) that may interfere with radio signals. Want proof... Take a portable AM radio around any room in the house. Almost guaranteed to hear noise from everywhere a switching function or bad connection is in use.
