Going all out for First quad build 250 class
G+_Brandon Rives
I need help with my parts list. This is what I have so far.
Order from ReadyToFlyQuads:
The Flip+ Deluxe FPV- with Add-ons
GPS: Mini (35x35) uBlox Neo-M8N GPS w/Compass
OSD: MINIMOSD W/ KV TEAM MOD V2.0
Right Angle pins Pins installed
Power distribution/ Current sensor: FULL SIZE POWER DISTRIBUTION (45X45) W/ 2 BEC AND VOLT/AMP APM SENSORS (with 30x30 mounting holes)
Telemetry:Bluetooth
4 RTF Motor 2208 - 2300KV - Advanced Series
NightHawk Fiberglass Mini Frame (250mm)
Silicone Wire HIgh Voltage - 14AWG, 1 meter red and 1 meter black
4-20A LittleDevil ESC BLHELI-(ONESHOT)-default settings
Lighting Strip (GREEN) and Lighting Strip (RED)
4-HQ Prop 5x4.5 Bullnose Fiberglass Composite Prop (Green)
4-HQ Prop 5x4.5 Bullnose Fiberglass Composite Prop (Orange)
From Banggood:
Eachine VR-007 VR007 5.8G 40CH HD FPV Goggles Video Glasses
Ordering soon list:
Receiver and transmitter = FrSky Taranis X9D with X8R receive
Turnigy 2200mAh 3S 20C Lipo Pack
Tenergy TB6-B 50W Balancing Charger for NiMH/NiCD/Li-PO/Li-Fe/SLA Battery Packs
Eachine 700TVL 1/3 Cmos FPV System 110 Degree Camera w/32CH Transmission (NTSC)
10 Pairs 180mm JST Connector Plug Cable Line Male+Female
Heat Shrink Tubing
Nylon Hex Spacers Screw Nut Stand-off
20 Pairs 2mm Gold Plated Male & Female Bullet Banana Plug
10 Pairs XT-60 XT60 Male Female Bullet Connectors Plugs
5.8Ghz Circular Polarized Clover Leaf Antenna High Gain
Any recommendation for thing I need to order or change to my order soon list. Thanks for all the help
  • 2 weeks later...
