G+_Brandon Rives Posted March 19, 2016 Share Posted March 19, 2016 First quadcopters build, it going to be fpv. Flight controller flip or kk? Link to comment Share on other sites More sharing options...
G+_Brandon Rives Posted March 19, 2016 Author Share Posted March 19, 2016 Any other recommendations would be good too Link to comment Share on other sites More sharing options...
G+_Rob Yesta Posted March 19, 2016 Share Posted March 19, 2016 What size? What use? Do you want telemetry and GPS? Altitude hold? Easy to change settings without computer? Acrobatic? Or smooth and steady? Budget? You can see this is a complicated question to answer. Your flight controller should be selected on your requirement. Link to comment Share on other sites More sharing options...
G+_Brandon Rives Posted March 19, 2016 Author Share Posted March 19, 2016 I am going to bite the bullet and get the FrSky Taranis X9D GPS would be nice, the wife will only give me the go ahead for 1 quad so I want to be able to switch between fpv and go pro for airal video and yes flips will be fun to, Link to comment Share on other sites More sharing options...
G+_Brandon Rives Posted March 19, 2016 Author Share Posted March 19, 2016 250 class Link to comment Share on other sites More sharing options...
G+_Brandon Rives Posted March 19, 2016 Author Share Posted March 19, 2016 Thanks Link to comment Share on other sites More sharing options...
G+_Brandon Rives Posted March 19, 2016 Author Share Posted March 19, 2016 No not really concerned about weight, and yes I know I have to register Link to comment Share on other sites More sharing options...
G+_Brandon Rives Posted March 20, 2016 Author Share Posted March 20, 2016 This has been very helpful Link to comment Share on other sites More sharing options...
