G+_Frederick Holtsberg Posted July 19, 2015 Share Posted July 19, 2015 I am having trouble with jello effects with my camera mounted to the front of my alien x quad build. I have balanced the propellers and even tried to pad the bottom and sides of the camera with foam but I still get the jello effect. I am also considering putting a gimbal on the bottom to see if that helps. Any suggestions? Link to comment Share on other sites More sharing options...
G+_Frederick Holtsberg Posted July 19, 2015 Author Share Posted July 19, 2015 Wayne Hobbins thanks, I will give that a try and see how it goes. Link to comment Share on other sites More sharing options...
G+_Conan Mills Posted July 19, 2015 Share Posted July 19, 2015 To add to what Wayne said, it can sometimes be caused by oscillations in the aircraft itself. The quad may be shifting left to right ever so slightly. You may want to look at you PID settings and see if you can tune some that out. Link to comment Share on other sites More sharing options...
