G+_Corr Dad Posted May 6, 2015 Share Posted May 6, 2015 I need a bit of help. I have a very early Mac Mini that I would like to hook up to my Samsung flat screen tv. What is the best way to make the audio and video connection? Link to comment Share on other sites More sharing options...
G+_Reed Hanson Posted May 6, 2015 Share Posted May 6, 2015 From the pictures I have seen, for video, you will need a DVI to VGA adapter and then a 3.5 mm stereo plug(both ends) to hook up your audio. Link to comment Share on other sites More sharing options...
G+_Corr Dad Posted May 6, 2015 Author Share Posted May 6, 2015 Thanks. Much appreciated. Link to comment Share on other sites More sharing options...
G+_Corr Dad Posted May 6, 2015 Author Share Posted May 6, 2015 Would a dvi to HDMI serve just as well Link to comment Share on other sites More sharing options...
G+_Kyle Jefcik Posted May 6, 2015 Share Posted May 6, 2015 DVI to HDMI will not carry the audio. You could use that for video, but you would still need the 3.5mm stereo plug. Link to comment Share on other sites More sharing options...
G+_Corr Dad Posted May 6, 2015 Author Share Posted May 6, 2015 great, thanks! Link to comment Share on other sites More sharing options...
G+_Phorest Sherwood Posted May 7, 2015 Share Posted May 7, 2015 Check your specs. I also have an old one that I did this with, and the headphone jack is also a fiber optic output. There is a special cable for this you can get on Amazon the will send audio to your stereo tos link. Link to comment Share on other sites More sharing options...
