I 'm Trying to fix a problem with my home office network
G+_Mike Showers
I'm Trying to fix a problem with my home/office network. I have a Verizon actiontec fios router running the connection to the Internet and my TV. It didn't get whole house coverage so I bought a Linksys WRT1900 AC to expand my network to other areas of the house. I've not been able to set up the Linksys router on the same SSID as the Actiontec. When I plug the Ethernet cable into one of the lan jacks on the Linksys it can't seem to find the Internet. So I can't set it up as Padre recommends. PS, I'm wary of trying to flash other systems on my expensive router, so I'm using the Linksys out of the box system.
You want to avoid NAT'ing a NAT... but if the Actiontech has an option to disable itself altogether and give the Linksys the WAN-side IP address. (aka the "REAL/Routable" IPaddress) then you can.
The problem with that is you lose the wireless network extension which is why you bought the 1900AC for in the first place. :(
Brian,
When I do that, I get the connection to the Internet, but the 1900AC won't work as an extension of the wireless. I have windows and Mac laptops, android and iPad tablets and phones. None of them seem to pick up an IP address from the 1900 when I turn off the dhcp function on the 1900 and set the SSID and passwords to the same as the actiontec.
What would happen if both routers were setup on the same network and both had DHCP enabled. They could both have the same default gateway (that of the Actiontech) and same subnet mask but different IP address ranges (say 100-149 on one and 150-199 on the other)? I know there could be conflict about who is actually providing the IPs, but would it matter?
Ben,
Right now, as a work around, I'm running DHCP on both. I have to manually switch from one to another when one signal gets stronger. Also, I can't see networked resources (printers, NAS) from the actiontec on the 1900 and vice versa. ?There are two different ip sets. The actiontec starts with the typical 192.168.....the 1900 starts with 10.
Wow. That's a pain lol. To be honest, I've never had issues with DHCP not working with that setup. DD-WRT has a DHCP forward option, but I'm pretty sure I've left that disabled. For my old junky D-Link router I just turned off DHCP and with a newer D-Link I did the same.
Maybe someone knows or you might be able to test... Does it matter if the static IP you assign to the Linksys in this situation have to be on the same subnet as the Actiontec? I wouldn't think so, but I'm not sure how involved the Linksys router would get involved in the DHCP request in this situation.
Ben, Brian, and Padre,
SUCCESS! I found the bridge setting in the manual. Thanks Ben. It was hidden in a drop down box online, so it wasn't something you would see just looking through the options online. I switched it to bridge mode, reset the router, then switched the SSID name. I had already given the Linksys router a static address on the actiontec so it was easy to find. Now I can walk around the house with my iPad and not have to switch between networks (unless I want to switch to the 5ghz to watch a movie). PS. To Brian's question, When you have FIOS, with TV, Verizon provides the Actiontec. It's both the router and modem as I understand it. It also is sort of the cable box for the TV. Thanks to all!?
