Know it alls I have a few Dlink DCS 932L security cameras to monitor a second home
G+_Mike Showers
Know it alls...I have a few Dlink DCS 932L security cameras to monitor a second home. I had been using them through the Dlink MyCloud Service. Last week the service went down, now I have to drive for four hours to unplug, then replug the cameras to get them to work.
My question is whether I could view the cameras without the cloud service anyway? It seems as though they are all small servers, with their own IP addresses inside of my home network. I would think that, if you know the addresses and can get a port through the firewall, you should be able to see them. Am I totally off base or is this something that should be doable?
I don't know about that model specifically, but many cameras do host an accessible stream and web server that you can access if you've opened your firewall to allow it. I've got a couple of older Trendnet cameras, each assigned to their own port.
If you're really adventurous you might look into the open source ZoneMinder project: zoneminder.com - ZoneMinder - Home
I had the same cameras a few years ago and got annoyed with having to login to each one to view them. Plus I wanted to setup some recording features. It's been a while but I believe I used a raspberry pi and motion to capture the image from each camera. With the raspberry pi you'd even be able to run a VPN and access them locally though their web config. Motion would be my solution though
It looks like those cameras are also on the compatibility list for Synology Surveillance Station. Of course, buying a Synology NAS would add a lot more cost than just replacing the cameras. If you have an old computer, though, Expenology is a "free" (if you have the hardware) option to run the Synology software yourself - including the Surveillance Station... Just a thought.
I really like the Pi idea too and that would be even cheaper if you can get it working. $50 to setup and probably pennies a day to run instead of the multiples of pennies it would cost to run a PC or even laptop.
VPN is a necessity for access (not really a necessity, just wouldn't recommend going without), but I'd really consider spinning my own instead of using the manufacturer's service - any day.
Mike Showers It is exactly this reason I did not purchase these cameras fitted into front area light fixture. Liked the idea of the camera being hidden and power available readily. Unfortunately when I contacted the vendor I was told the monthly service fee and service were required. Deal breaker for me and you have experienced the reason for my shying away from the unit. If there is a way to bypass their service I would readily go back and pick up the camera/lightfixture product.
I haven't had to pay monthly since I don't ask for storage. My main concern is that the cameras were going through someone else's service, where I couldn't limit access. Who knows who at DLink has access to the camera feeds.
But I do have a few old PCs around that I've been thinking about repurposing. Perhaps Ben's idea to set up a NAS with Expenology is the answer. It'll be a new experience for me. Time to start investigating.
I'm using an Apple AirPort Extreme as the router. I'm not sure how much flexibility it has to operate as a VPN server. I'm actually leaning towards getting one of the less expensive Synology NAS boxes though as I could also use it for offsite backup from my regular home. I'm not sure I know enough to set up my own server on an old computer.
Synology can run an OpenVPN server if you go that route. I've also run one on the original Pi B and now my OpenVPN server is a Debian VM.
I don't have any experience with the Apple routers, but I doubt they can act as an openvpn server without some software modifications. DD-WRT and probably Tomato and OpenWRT can act as an OpenVPN server or client.
