Can someone give me some help with setting up my MythTV box?
G+_Brandon Butler
I have setup my MythTV box. I am able to watch tv but can only change the channel by the cable box remote. I need help in setting it up to change the channels through the Mythtv box.
I have a Motorola QIP7100 2 Set top box. I have it connected via firewire to the Mythtv box. I'm not sure how to configure it to change channels via the firewire connection. I know some data can be transmitted over the cable because I originally tried to get the video over it but its locked.
Alternatively I've also considered using either an IR blaster or a serial cable.
If anyone has a functioning setup using any of these configurations I'd appreciate your help with getting this setup.
I have done a little bit more research and decided to go with the HDHomeRun Prime. From what I have read, it will work out of the box with Mythtv. I'll just need to get a cable card from Verizon.
I also have Plex installed as well. When I get it all setup my plan is to use Mythweb to schedule the recordings and watch them via Plex on my Roku.
