Stumped I have a machine with an Asus M3n78 pro motherboard and 4GB RAM The system has been ...
G+_Craig Strutt
Stumped.  I have a machine with an Asus M3n78 pro motherboard and 4GB RAM.  The system has been running Windows XP for several years with no problems.   Pop in the Windows 7 Home Premium disk.  The system freezes at various points.  Most commonly at or immediately after the Starting windows screen with the colored screen.   I had a graphics card in the machine, which I removed and used the onboard graphics - same result.  I've updated the bios to the latest revision - same result.   I've unplugged any added equipment except for the keyboard / mouse (both USB) / monitor / hard drives - same result.  I've ordered new memory just to check.   Never run into this before and I'm STUMPED!
You can't upgrade XP, has to be clean.  Although it never got far enough to have that option.   I haven't run memtest, (though I've already ordered new RAM) but I'll try that today.  I did take a copy of Windows 7 ultra (which does try to install fresh within an already booted XP) and let it start.  It froze on the first re-boot at the same point.
This might be a stupid question depending on your tech level, so if that is the case, I apologize in advance. However, the symptoms you are describing can happen if the RAM cannot support the front side bus speeds expected; i.e. like using 1333MHz RAM when 1600MHz RAM is required. Are you sure you have the right speed RAM?
