Has anyone built an Arduino or Raspberry Pi project that will flash lights with the beat of music...
G+_Darrell Sullivan
There's a program called Vixen, but thats probably not what you're looking for since I believe it's a manual process. Actual beat detection is apparently difficult. You might be able to get by with a low pass filter, but that may not be as effective for all songs.
I found this blog post from a year ago and the author says his code works, but obviously I haven't tested it: http://dpeckett.com/beat-detection-on-the-arduino
A while ago, I made christmas window candles flash to music on a radio station. But I used a computer running a program I made utilizing a language called processing. This language had a library that had beat detection. Then the computer would talk to the arduino which then talked to a bunch of arduinos through cheap radios.
It would probably be simple to do this on the raspi. Just look for an audio analyzing library for your favorite program language.
