G+_Magnus Jansson Edqvist Posted November 12, 2015 Share Posted November 12, 2015 is there a way to send movies,music and pictures to a tv via wifi from a Synology NAS without having to use your mobile phone? will it work with samsung smart tv and find it with DLNA? Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted November 12, 2015 Share Posted November 12, 2015 Cromecast. $35. Mic dropped. Link to comment Share on other sites More sharing options...
G+_Magnus Jansson Edqvist Posted November 12, 2015 Author Share Posted November 12, 2015 ok thanks but I thought the chromcast did not had an interface so that you had to use your phone/tablet to mirror things on it. am I wrong? Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted November 12, 2015 Share Posted November 12, 2015 You are right that it does not have it's own management interface. You use the app on your phone/tablet and press a button to send the video/picture to the chromecast. The chromecast then streams the feed your watching via it's own wifi connection. Now I also see that is not what you want to do. The Synology NAS should have DLNA server software, which should then be picked up by the smart tv after it's configured properly. Link to comment Share on other sites More sharing options...
G+_Black Merc Posted November 12, 2015 Share Posted November 12, 2015 Raspberry Pi is an option... turn your dumb flat screen to a device that can doitall! Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted November 13, 2015 Share Posted November 13, 2015 Yup, KODI on anything (such as the amazing Pi) can access DLNA content. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted November 13, 2015 Share Posted November 13, 2015 Also, if you're already an Amazon Prime user, you might just get a Fire TV Stick. I'm sure there are multiple DLNA apps in their App Store and if you can't find anything else you can side-load KODI. ? Also, a ROKU would work... Also I think there's a Plex server app for your Synology and there are Plex clients for practically every OS. Link to comment Share on other sites More sharing options...
G+_Peter Hanse Posted November 13, 2015 Share Posted November 13, 2015 Believe if you have Apple TV you can send directly to Apple TV via ds video web interface Link to comment Share on other sites More sharing options...
G+_Magnus Jansson Edqvist Posted November 13, 2015 Author Share Posted November 13, 2015 I have an apple tv 3, Can I get DS video on the or is it only the 4th that have that? I´m in Sweden so we don´t hav amazon. do any of you recommend a good smart tv ror the bedroom? Link to comment Share on other sites More sharing options...
G+_Peter Hanse Posted November 13, 2015 Share Posted November 13, 2015 You would use DS Video on Computer via web browser or using iOS app. Synology website talkes about in TV Streaming https://www.synology.com/en-global/dsm/5.2/multimedia Photo of my DS Video Station where to select Apple TV https://plus.google.com/102338616602830154188/posts/gEAksnNAGof Link to comment Share on other sites More sharing options...
G+_Magnus Jansson Edqvist Posted November 13, 2015 Author Share Posted November 13, 2015 so if I want to just use the tv as a remote do I need a smart tv then? Link to comment Share on other sites More sharing options...
G+_Black Merc Posted November 13, 2015 Share Posted November 13, 2015 Magnus Jansson Edqvist or the Raspberry Pi. All a smart TV is: a TV with more computing power than is required to be a TV and a network (Lan/WiFi) connection. Some blueray players have this function too. But, IMHO not well enough to play multimedia from your private network sources(nas, mmpc). Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted November 13, 2015 Share Posted November 13, 2015 I'm not a big fan of "Smart" tvs because there's no way to upgrade them. That said, I think I remember seeing a Plex app available for my Vizio (I never use any of their apps, but I hear Vizio is one of the better for smarts). Going with a Roku, Nexus Player, etc - maybe even Apple TV - is almost always better than the TV smarts. Link to comment Share on other sites More sharing options...
