what should I use to get power to my B6 Max lipo battery charger for 3 cell lipo batteries for qu...
G+_Daniel Naberhaus
I use one of these chargers, but I'm not sure I understand your question.
The charger is powered by any "brick" that converts whatever wall outlet voltage you have (110 or 220) down to 12 v DC, with the center conductor of the plug being +.
Once you have the proper power adapter connected, you connect the LiPo battery and then change the settings to 7.1 v and then press Start.
