G+_Kenneth Ojeke Posted October 9, 2017 Share Posted October 9, 2017 Hello Guys, i am setting up a low budget wireless network in a friend apartment, a duplex with a penthouse and he want connectivity in all room. I got 5 unit of Trendnet AP (TEW-638PAP) i will installed one on each floor and install the remaining two at any dead spot i notice. i have set the channel on 3, 6 and 9 I want to achieve the following: Same SSID and password on all APs. Users can roam without losing connection. I need suggestion for the best IT geeks. Link to comment Share on other sites More sharing options...
G+_Black Merc Posted October 9, 2017 Share Posted October 9, 2017 USA? Best channel spread would be 1,6,11. No overlapping channels with this spread... Even marginal overlap will slow speed. Link to comment Share on other sites More sharing options...
G+_Michael Hagberg Posted October 9, 2017 Share Posted October 9, 2017 I use WiFi analyzer, an Android app, to first view what channels nearby neighbors are using. Link to comment Share on other sites More sharing options...
G+_David Peach Posted October 9, 2017 Share Posted October 9, 2017 On my APs at the office I set the same SSID and password on all of them and they hand off as I roam around the building. Link to comment Share on other sites More sharing options...
G+_Kenneth Ojeke Posted October 9, 2017 Author Share Posted October 9, 2017 David Peach thanks David, for office environment, i think you should a controller or you are using APs like ubiquiti APs. what type are you using? Link to comment Share on other sites More sharing options...
G+_Kenneth Ojeke Posted October 9, 2017 Author Share Posted October 9, 2017 Black Merc thanks i will try it Link to comment Share on other sites More sharing options...
G+_David Peach Posted October 9, 2017 Share Posted October 9, 2017 Kenneth Ojeke, yes, I am using Ubiquiti APs for the office. But even before I bought my second Ubiquiti, I had a Cisco AP that worked the same. I set them both to the same SSID and it worked perfectly. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted October 9, 2017 Share Posted October 9, 2017 Kenneth Ojeke, when you get it up and working would you be so kind as to post your working finished project? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted October 10, 2017 Share Posted October 10, 2017 Yes to all of that. Channels 1, 6, 11 are the only channels that should be used. If you choose to use 40 Mhz, you'll get even fewer channels; but I'm not sure that will even be an option with those Trendnet APs. You can use Wi-Fi Analyzer to find which channel is best to use at each level. Like, if a neighbor has a strong AP on channel 1 but it's only barely visible on your 3rd floor, put your top AP on channel 1. You may also find that 1 or 2 APs is all you need. I've got a cheap TP-Link access point that has a decent signal through my whole house (3 floors total). And giving them all the same SSID and password should allow you to roam freely. You may have options to adjust RSSI. I've never messed with it, but that may be an option if devices are having a hard time letting go of the AP that's farther away. Basically just the AP initiating the disconnect when signal gets too low. Just my 2¢ Link to comment Share on other sites More sharing options...
G+_J Miller Posted October 10, 2017 Share Posted October 10, 2017 I use these WAPs. All on same SSID and password. Lets me go from one to the other when signal gets low enough. tp-link.com - TL-WA801ND | 300Mbps Wireless N Access Point | TP-Link Link to comment Share on other sites More sharing options...
