I 'm about to build my first quad, and I 'm planning on doing a 250 based on the one built in t...
G+_Jesse Kawell
I'm about to build my first quad, and I'm planning on doing a 250 based on the one built in the first quad series on KH, but the kit recommended (HobbyKing Spec FPV250) seems to have been on backorder for a long time. Any recommendations for a good starter 250 kit that I could actually get in a reasonable amount of time (and in the same $100-125 price range)? Thanks!
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=52863
I bought that kit and the laser 230 frame and used that instead, then I upgraded to some 2300kv dys motors, save yourself some money, buy any 250 frame you like (the laser type gives more room with another layer) and get the more powerful motors like dys or multistar elites, you'll want them eventually ?
